P
peaps
If it wasn't there's be cracks elsewhere.
Not the case I'm affraid. The float coat can lift without cracking the finish and if the float coat has lifted then odds are the whole wall will be suspect.
who said anything about pvaing a fresh float coat? if you read my post i said if the float coat had been allowed to dry outideally the undercoat should not dry out b4 skimming, it should still be damp when skimmed or if it did dry out it should have been damped down again or primed with pva, to treat this problem i would start at the crack with a scraper and take as much off as i can that i feel has blown or has not taken and then repair, you may end up taking all the wall off or it may just be localised "If YOUR LUCKY"you have confirmed my thoughts that the undercoat was put on and not allowed to settle and dry before the skim
Why would you pva a fresh floatcoat..?
It looks like the flat coat wasn't applied to a correctly prept background. Clean off dust and debris, wet down, scratch coat then float. Looks like the float coat has lifted.
Why would you pva the float coat if it had been allowed to dry out? I don't get it....
Stop talking bollex.
if you have been a spread for 23 years and dont know the answer then ill leave you guessingYou going to answer the question?
peaps you have only been on this forum for a few days and have tried your best to wind people up, instead of trying to answer questions by ops and being helpfulif you have been a spread for 23 years and dont know the answer then ill leave you guessingYou going to answer the question?
Well if you are not confident in backing up your working practice then I'll leave you thinkng it's good practice
hahaHere, here
The last thing this forum needs is yet another troll
