Crack prevention at top of door.
30 Mar 2012
Monmouthshire
I have a 1st floor block wall with doorway to build and was wondering if I should mesh the door corners. Low ceilings provide only 9.5" above the door frame. The wall isn't loadbearing and is perp to an exterior wall that has no cavity in it's lower half.
Does it make any difference to increase the cill bearing beyond what is necessary? Or should I just put in a normal cill, mesh it before render etc and that's as good as corner crack prevention gets?
Thanks guys,
Dain
