We had a black composite door fitted a few years ago. It has started to stick in the frame at the bottom of the door and this is due to water ingress which has swelled the timber of the door and separating the face and side plastic coverings.
The water ingress seems to have happened along cracks that have appeared in the plastic of the front door and run at 45 degrees from each of the corners of the bottom panels - it is a 4 panel door.
Is this a common problem? Has anyone seen it before oar was the door not bonded properly in manufacture?
It was not a budget door!!!!!!!!!!!!!!!
