I have a new Composite front door to install. It came with 2 glazed side panels which are separate and some joiner strips. The door is already hung in it's frame. It's quite obvious that the glazing in the side panels should be removed before fitting the frame, Which I have already done, but what is not so obvious is whether or not to remove the door from the frame before fitting. Weighing in @55Kg it would make sense to remove it and get the frame in and square/plumb first. But is this a good idea?
Also I asked for a fixing kit with the door, but it only came with 8x8mm frame screws and 3 50mm screws for the sill. No wall plugs for the frame screws and nothing to join the the side panels to the door. I'm assuming that I need some screws to attach the door frame to the side panels and the masonry plastic plugs for the frame screws ...
