cracks in ceilings
31 Oct 2005
Cheshire
My bathroom ceiling has four cracks emanating from the light rose. I have deepened the cracks and been told to fill them with builders\\\' flexible caulk. Whilst clearing the cracks I have removed some of the paint on the ceiling so that bare plaster is exposed alongside the cracks and the present emulsion is no longer a smooth surface; some of the ceiling is painted and some is bare plaster. What is the best way to ensure that I end up with a smooth ceiling? Do I paint the bare surface more than I will paint the rest of the ceiling?
Thanks for any advice. I read on your site that you recommend the use of filler. Won't this "crack up" again? Hence being told to use flexible caulk.
Depends on the nature of the cracks really..caulk is ok but it does tend to shrink....so you'l have to do a few appications...
The thing you have to be careful of is 'scars' forming on the ceiling because of the filler......if the ceiling was painted with a rooler before then touch up any filler using a radiator roller, this should help get the 'texture' back...
