Cracks internally and externally around landing window – should I be concerned?
17 Dec 2018
I'm looking for some advice on cracking around a first-floor landing window in my house.
There is an external crack on the wall which runs from approximately two feet above ground level up towards the corner of the landing window.
The crack has been there for a long time, as far as I'm aware.
However, I've now noticed several cracks internally around the same window. I've attached photographs showing the external and internal cracking.
The internal cracks appear to run diagonally from the corner of the window, with some additional cracking across the wall.
A few details:
  • The external crack is on a different wall from the bedroom ceiling issues I'm also dealing with.
  • The external crack is longstanding.
  • The internal cracks are now becoming noticeable.
  • There is no known ongoing water leak.
I'm wondering whether this could simply be historic settlement, or whether it might indicate movement around the window or a problem with the lintel.
My questions are:
  1. Does the pattern of cracking suggest possible subsidence or structural movement?
  2. Could a failing or inadequate lintel cause these internal and external cracks?
  3. Would you recommend getting a structural engineer to inspect it before replastering?
  4. Is there anything specific I should look for in the external brickwork to help identify the cause?
I'd appreciate opinions from anyone who has experience with this type of cracking. I'd rather establish the cause before spending money repairing and redecorating the wall.
Get it surveyed. Then, you will know what you are dealing with and what to do.
For the external views, you ideally need to show as much of the side of the house as possible so that the context can be seen. It's often difficult to impossible to diagnose cracks with a close-up view.
Internally I would say nothing to worry about. Externally, if it's been there a long time, again, nothing to worry about but, if it were me I would get an SE in for peace of mind.
