Creating a form for pouring a concrete path!
7 Feb 2012
Middlesex
Hello, I want to pour a path and have previously used 12mm ply with timber steaks used every 30cm.
Due to cost I want to know if anyone has used a cheaper material like OSB?
Love to hear
Anything will do as long as its stiff enough. If its only for a path i'm assuming its 100mm and its not like your going to be putting a vibrating poker in it.
12mm is fine as long as you stake it well.
Longer lengths are easier obviously as they need less staking and lining up.
3 x 4.8m lengths of 4x1'' timber will be similar price to a board of osb? and easier to work with as its one single piece.
of course if its a large area then one sheet could be ripped into 12 100mm x 2.4m lengths
OSB will give a rough finish to the side of the path but that doesn't matter if your margin trowelling it, which you should do!!
