My daughter has asked if I can make her a space outside for her to practice basketball.
The most sensible space I can see is a rarely used part of the drive which currently has chips on it but is actually a massive concrete slab underneath. I plan to remove the chips but I think the actual slab surface is a bit rough so not ideal for basketball.
I'd like to put down some sort of simple covering so she can use the surface. I had looked at using a simple self levelling compound however I know they aren't intended as the final surface so many not last long at all.
Are there any other products you're aware of that could be used to level/smooth out the surface? Ideally I'd prefer not to put slabs down as we would still like to have the option of using the space for cars if needed.
Any ideas greatly appreciated.
Cheers.
Cheers.
