I'm about to build a deck on top of an exisitng concrete slab, I will use bolt down Metposts to hold a couple of posts in place.
The exisitng concrete slab is rough and uneven so I will smooth some concrete to form a smooth, level surface for the Metpost to sit on.
1/. I assume I should use 6 sharp sand, 1 cement?
2/. If I use quick drying cement can I drill through and fix the Metpost the same day?
Any help much appreciated.
