Hello,
and help! I think I've answered my own question, but would appreciate any clarification/correction.
We have started long bubbles in the paint on the upstairs ceilings, the worst runs the whole width of the room, is a good 10 cm across and sagging by about 5 mm. But shining a light across the ceiling shows up lines on pretty much every part of every ceiling upstairs, roughly at about the point you'd expect the edges of plasterboard. (none are less than about 90cm apart) all stretch most of the length/width of the ceiling.
Is this just an extreme case of the paint cracking/peeling with natural contraction/expansion, or something more sinister?
Where there is movement it certainly seems to be just the paint, maybe paint + paper/tape, but definitely not the whole board, I've checked above the main one for moisture and no sign of water or water sources; and as I said, it's there to a lesser extent everywhere.
Edit to add they're not freshly painted, were painted over about 3 years ago.
Edit #2, just got the courage to start poking around a bit, and most of the lines are solid, no movement at all, it's just lumpy, but in perfect lines! only movement in a few areas, still in lines though
any input would be appreciated, especially if someone's seen this before!
thanks.
Jeff
thanks.
Jeff
