hi everyone ,im having a bit of a nightmare with a shower i have just installed,i have fitted a shower thermostatic mixer valve about 5 metres away from the HWC i have had to raise the cwst into the loft from the airing cupboard,i have got a positive head of about 2 feet from the top of the shower head to the bottom of the tank in the loft,so basically not enough so thats why i fitted a salamander ct 50 pump 1.5 bar i have give the pump its own individual feeds ie the cold inlet from the cwsc and the hot via a salamander s flange comes off in 22mm the reduced straight into the pump inlet in 15mm. both outlet then go straight up into the loft in 15mm across the loft about 5 metres then down into the shower itself.the problem is the hot wont come through the cold is fine.i thought it might be an airlock so i fitted an aav directly above the hot shower pipework but still no joy i rang salamander they sent me a non return valve for the hot still no joy the tank i 25 gallons but it still should draw the hot threw please someone help me i am losing my mind on this job please help....
