SALAMANDER CT50 Shower Pump
6 Jan 2009
Lincolnshire
Hi all,
Looking at doing a new install for a mixer shower with a Salamander shower pump. My problem is which pump to use!!
The hot water tank is located approx 12 metres from the location of the shower, with the new pipework being installed from the hot tank on the first floor level, up into the loft and across pprox 12 metres to the bathroom, then down into an exposed Mira Discovery with 4 head spray pattern shower head.
What pump would be recommened for this application, bearing in mind the pump will also have to be fitted above the level of the hot water tank as there is not enough room in airing cupboard to fit the pump to the floor.
Any help or advice, much appreciated.
