Custom made radiators
28 Aug 2009
Cheshire
Can anyone point me in the diretion of someone who can either custom make or modify a radiatior.
What I am after is a vertical, right angled radiator to fit around the wall that encloses the waste water pipe that runs floor to ceiling. The wall around the waste water pipe measures 260mm by 260mm.
GALLERY]
i doubt very much if your boxing in will take the weight off a radiator on top off that if you try folding to right angles you wont get any flow
my suggestion would be 2x2 battons on the walls to form a triangular space clearing the boxing in by around 50mm somwhere about 550mm from the corner
4x1" bearers crossing between the battons at radiator fix points
then you can use a 700-800mm radiator to cover the area
i would expect a special radiator made or adapted would be £200-600 as a rough guess depending on requirements
