Cut away gap between wall and house
21 Aug 2006
Buckinghamshire
Hi all
I have a wall that is built next to my house and this corner is always damp over the DPM.
what is the best method of cutting a 1inch gap to allow the rain water to run away rather that sit between the wall and house.
Should i buy a masonary saw or is there some form of cutter that could make mince meat if this in a few moments.
the wall runs about 6 inches down the side of the house.
would a normal builder have a tool that could cut upwards and fix this problem?
thanks all
There does appear to be an obvious flaw there. The dpc, if there is one, is breached by the brickwork in the wall. Also the coping stone directs rainwater towards the house wall.
A builder should have access to a 9" angle grinder which will relatively quickly cut through, first from one side then the other.
There will be a lot of dust and some tidying of brickwork afterwards.
There might be some consideration of the stability of the wall required afterwards.
thanks for your advice.
I have had DPC installed at the front of the house but not the back yet as the wall is the first step to remove damp then i will get a DPC instaled and start thinking about plastering after a few months of drying out.
thanks so much
If you wanted you could correct the problem.
Remove the first few lines of brickwork and rebuild it properly, with a vertical dpc and a wall starter kit.
Also the coping stone should have been cut with a mitre so that the bit nearest the wall didn't direct water towards the house wall.
There should not be a great deal of dampness migrating across purely due the way the wall is built. There is no specific staining indicating dampness at low level
The biggest problem would be that end coping stone, and the way it angles down towards the main house wall. You need some sort of angle fillet on there to cast any rainwater away from the house wall.
Also, check if those copings have a recessed drip on the overhanging section
There does also seem a lot of pointing which needs addressing
