    Dismiss Notice
Cut plasterboard too big for 1 gang socket
Discussion in 'Electrics UK' started by SpecialK, 28 Jul 2019.
  1. SpecialK
    SpecialK
    27 Sep 2010
    304
    Thanks Received:
    29
    Country:
    Stupidly I have marked around the front of the plasterboard box and cut the wall.
    The hole is now too big (argh) but the lugs still attach to the wall.
    What is the best way out of this mess? Thankfully its in a cupboard under the stairs so doesn't need to be too pretty....
  2. Sponsored Links
  3. JohnW2
    JohnW2
    28 Jan 2011
    42,506
    Thanks Received:
    2,697
    Buckinghamshire
    Country:
    If it were me (and we've all done such things!), I'd probably glue small strips of plasterboard onto the sides of the hole (maybe only one side and one top or bottom).
    Kind Regards, John
    • Like Like x 2
  4. SUNRAY
    SUNRAY
    28 Jul 2009
    2,142
    Thanks Received:
    108
    Kent
    Country:
    https://www.nationallampsandcompone...FMpFr6vYlwohbUj_34ZnMSkL4hfbE8c8aAstMEALw_wcB
    OR
    cut it bigger and fit a 2 gang for security then a finger plate to cover the gaps.
    • Like Like x 2
  5. Taylortwocities
    Taylortwocities
    28 Jul 2006
    18,768
    Thanks Received:
    1,880
    Oxfordshire
    Country:
    • Like Like x 1
  6. sparkwright
    sparkwright
    20 Aug 2009
    7,139
    Thanks Received:
    870
    Dorset
    Country:
    Can you fit the cut-out back in place, and fix with a piece of batten and some woodscrews.
    And then cut a new hole for the box to the left or right, or above or below??
    • Like Like x 1
  7. Sponsored Links
  8. SUNRAY
    SUNRAY
    28 Jul 2009
    2,142
    Thanks Received:
    108
    Kent
    Country:
    You didn't say what size.
    If it's single gang then extend both sides (But not full height!! and use a 2 gang.
    If it's 2 gang then extend both sides (But not full height!! and use a dual: https://www.screwfix.com/p/appleby-dual-35mm-dry-lining-box/22772 (that was the fix I did and used 2 single sockets instead of a double)
    or if you actually need a 2 gang: https://www.screwfix.com/p/appleby-dual-35mm-double-single-dry-lining-box/60079 and a blanking plate.
    • Like Like x 1
  9. JohnD
    JohnD
    15 Nov 2005
    61,085
    Thanks Received:
    3,215
    Perth
    Country:
    Cook Islands
    yes he did
    • Like Like x 1
  10. SUNRAY
    SUNRAY
    28 Jul 2009
    2,142
    Thanks Received:
    108
    Kent
    Country:
    wood for the trees...
  11. JohnW2
    JohnW2
    28 Jan 2011
    42,506
    Thanks Received:
    2,697
    Buckinghamshire
    Country:
    Don't feel bad, I've certainly done the same myself, more than once (and nearly did this time!) - when information is contained in the title of a thread, but not in any of the messages the thread contains, it's very easy to overlook it!
    Kind Regards, John
  12. SpecialK
    SpecialK
    27 Sep 2010
    304
    Thanks Received:
    29
    Country:
    Thanks everyone - I will put in the dual 1 gang!
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
