    Dismiss Notice
Cutting a porcelain tile
Discussion in 'Tiling' started by russell allan, 5 Dec 2015.
  1. russell allan
    russell allan
    15 Nov 2015
    3
    Thanks Received:
    Country:
    Morning all..... I'm trying to cut a porcelain tile its 985x215 I'm taking 200 off the lenth using a fairly robust manual tile cutter I've made several passes to scribe the line of cutting but when I press down on the handle to make it crack on the line it does not seem to want to go.... not sure if I should force more pressure onto it I'm worried about damaging the larger part of the tile
    any help would be appreciated.
    ps. I have an electric wet tile cutting wheel but was hoping to limit it to the complicated cuts.
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    Is it professional rail cutter or is it a cheapo type?
    Does the cutting tip/blade need replacing?
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
