And will no doubt be totally blunt which then leads to acquiring another skill and equipment in sharpening them.If you haven't inherited one, they are available at jumble sales. No I wouldn't suggest buying a new one!
A workmate (work bench) is all you need.I find the hardest thing is supporting the door while working on it - there's tips about how to make simple jigs for that.
You need to measure the door aperture in the door lining (frame) top, middle and bottom. Also measure the height at both sides. Record those measurements. Hopefully the door aperture will be a standard size. If it isn't then you should buy doors the next size up, you have a maximum of 16mm (8mm for each side) that can be trimmed off if necessary.
The angled is so slight that I usually plane it square and then I do a last very light pass on an angle.The 'keeping the plane square in use', needs some practice, but note - the lock side of the door shouldn't be perfectly square. The edge which enters the frame first, is supposed to be planed a little more, than the inner edge. So the edge has a very slight angle.
It can be done by a competent diyer, however, the results will not be great on first door.
Do you have a palm router?
Without it, prepare yourself for some swearing.
Well you can do it with a workmate - but it's 'kin 'ard work. Doing the sides is passable, but the door wobbles a lot unless you clamp it so tight it risks marking the door. Doing the top & bottom means clamping the side of the door, with the workmate cockled over and working high up in the air.A workmate (work bench) is all you need.
It depends how tall (or short) you are.Well you can do it with a workmate - but it's 'kin 'ard work. Doing the sides is passable, but the door wobbles a lot unless you clamp it so tight it risks marking the door. Doing the top & bottom means clamping the side of the door, with the workmate cockled over and working high up in the air.
