Cutting cedar battens
16 May 2021
Hi!
I'm having some cedar battens delivered tomorrow and will be starting to make the panels shortly. I have an Evolution 255DB+ compound mitre saw which has worked well for me so far. I currently have multipurpose blade that came with the saw on it. Do you think I should buy a fine wood cutting blade like this? https://shop.evolutionpowertools.com/collections/evolution-blades/products/255mm-fine-wood-blade-60t
Seems fairly pricey. I'm setting up a stop block which should aid the cutting process.
Any guidance/comments welcome.
Many thanks,
E
Making up screens that will hopefully look like this...
Start off with an experimental cut or two, see how it fairs ....
Dunno why you're looking for Evolution blades or on the Evolution website though, silly prices on there.
Hi!
Many thanks,
E
I would get a Freud blade
No me neither. It was because I was looking at which blade came with the saw. I've seen some much more reasonably priced wood blades now on other sites
If you add a timber fence and timber base it will virtually prevent any break out on the bottom and rear - set the depth stop so the blade doesn’t got right through the base.
Be careful to get a blade with the correct bore.
250mm blades will also be fine.
Western Red Cedar is very soft so just cut through gently
as an aside
always cut for the largest panel/space first then any mistakes have somewhere else you can use them
when planning cutting long length economically, do not be overeconomic as you ideally need to allow for blade thickness x number off cuts plus say 20mm for uneven/damaged ends to be cut out
also note twists bows dammage curves and cut them out or iff you have to use most cut out plan big bits off movement on very short bits and in areas where visible is less obvious
allow between 5-10% extra for wastage
remember preworked size can be up to 18% smaller to actual size after machining so check for coverage[surface it will cover in use]
