cutting down a door
Discussion in 'Windows and Doors' started by slyman1, 15 Nov 2004.
  1. slyman1
    slyman1
    15 Nov 2004
    6
    Thanks Received:
    Country:
    I need to take about 2 cm of the bottom of a wooden door!!
    Do u HAVE to plane it or can u just use a jigsaw??????
    ANY HELP WOULD BE GREAT
    SIMON
  2. Sponsored Links
  3. P.J.
    P.J.
    4 May 2004
    107
    Thanks Received:
    Hampshire
    Country:
    I'm not a pro but I would cut it by any means, leaving about 2 or 3mm over, and then finish it back with a plane.
    Watch out though, you should really take even amounts off top and bottom to avoid weakening the joints - I think 2cm should be OK to take all off the bottom but you need to check.
    Cheers,
    P.J.
  4. Thermo
    Thermo
    21 Oct 2004
    9,979
    Thanks Received:
    150
    Sussex
    Country:
    generally the bottom stile of a door is wider than the top to allow for such an adjustment. i would use a circular saw and a straight edge clamped on. Make sure you leave the cut generous and then plane it to get it smooth and exactly level.
    I trust when you say its a wooden door, you mean a solid one. If its an internal boarded door then you will have to top and bottom it as the battens inside are generally only 50mm thick
    Thermo
  5. muffking
    muffking
    2 Dec 2004
    434
    Thanks Received:
    25
    Lincolnshire
    Country:
    That's exactly why I bought solid doors, 'cos I didn't know if I could get away with chopping the ends of hollow doors :eek:
  6. Thermo
    Thermo
    21 Oct 2004
    9,979
    Thanks Received:
    150
    Sussex
    Country:
    theres your answer then!
  7. AS
    AS
    24 Nov 2004
    66
    Thanks Received:
    Country:
    Does the same apply if you need to reduce the width of a wooden front door?
  8. big-all
    big-all
    12 Jul 2004
    19,159
    Thanks Received:
    1,513
    Surrey
    Country:
    yes thats assuming you are talking about simmilar sizes
    but in general you check the frame for square [hold the door up against it]cos if you just measure top to bottom and cut and its out of square you finish up with further work and a triangular gap some where
    would also avoid jigsaws on doors unless you know your jigsaw well and you know it dosnt wonder off line with a sharp blade
    by this i mean you follow the line but the blade goes off to the side and at an angle
    try it on a 45mm thick piece off wood first to see
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
