Cutting metal handrail
......with very fine teeth or an angle grinder with a 1mm slitting disc.
This is very thin wall stuff - dead easy to crush in the vice so carefully does it!
John :)
Worth wrapping some masking tape around the area you're cutting. It will help to stop the blade slipping as you start the cut.
Nothing worse than a big scratch right across your shiny new pole!
Thanks for the replies, all done, hacksaw worked a treat.
