cutting slots in tiles
8 Nov 2004
is there any easy way to cut a slot in a tile, i can do the 2 side cuts with a tile cutter but how can you then make the final cut cleanly, hope this is clear 2 cuts parallel to each other then remove the bit between the 2 cuts
thanks
Bill
Do you mean a slot as in letterbox?
or
Do you mean a rectangle from 1 side, if thats what you mean you can nibble the bit away with pliers or with a tile saw cut it away, or file it.
Two side cuts with a wet cutter, third cut with a manual cutter then snap the waste out.
Jason
