cutting tiles around a quadrant shower tray
21 Jun 2011
Buckinghamshire
I'm nearly at the point where I need to cut the tiles to follow the curve of the shower tray and wondered if anyone had any tools or tips thay can recommend to do this job.
I've layed all the tiles out on the floor and done the majority of the cuts as a dry fit including putting the tray on top of the tiles to be able to draw out the curve but it occured to me at this point to see if it is possible/ advisable to tile under the tray and then simply lay the tray over the top and therefore avoiding any cuts?
I realise that this is a waste of tiles but I'm sure i can afford to sacrifice 4 or 5 tiles.
Not sure i'd want to tile under it, whats the floor made of?
As for cutting, should be pretty easy, a hand held grinder with a diamond wheel will cut them fine.
Will make alot of dust.
You could also cut them straight and use nibblers to make the curve, just as neat with practice.
Can also be done on a wet diamond cutter, cut from the edge into the curve so you end up with what looks like a comb, then snap out the prongs.
Hard to describe.
Depends on your skill levels, i'd guess the easiest way for a DIY'er would be the hand held grinder to cut the curve.
Don't tile under the tray, it needs to be on cement/18mm ply etc.
I do what Graemevw does with the diamond wet wheel cutter (£40 job from B&Q will do). Just keep slicing and filing and offering up to check.
