Cutting tiles in situ.
19 Aug 2010
Luton
Hi all,
I need to cut some already fixed wall tiles to accomodate an IKEA kitchen. I guess a decent blade in an angle grinder should do (reccomendations anyone?) but there are a couple of inside corners to cope with and I'm not sure my 115mm angle grinder will manage those.
Any ideas?
Used one of these on my 115mm grinder.
Worked well and reasonable price. Creates a LOT of dust. Mine were cut outside.
Grinder, multi tool, Bosch PKS16, palm router , with correct blade/bit .
Never seen the PKS16 before.
I guess an advantage of it having such a small blade is that it will leave less material to remove when doing the internal corner cuts.
Dust extract and depth stop helps cut in the room you are working , cuts timber as well.
Yeah fair play. I am lucky enough to be able to justify the cost of both a plunge angle grinder and plunge saw that both run along guide rails, but they are beyond the budget of DIYers.
