    Dismiss Notice
Cutting up old kerosene oil tanks
Discussion in 'Plumbing and Central Heating' started by Mike2007, 30 Aug 2019.
  1. Mike2007
    Mike2007
    10 Feb 2007
    1,282
    Thanks Received:
    32
    Cumbria
    Country:
    I have two kero tanks in a basement that have to go, how does everyone handle removing old tanks?
    Obviously kerosene is flammable, but not very flammable, with a grinder producing sparks.
    Thanks in advance
  2. Jackrae
    Jackrae
    20 Nov 2012
    2,063
    Thanks Received:
    338
    Dumfriesshire
    Country:
    Don't you believe it. Once the kero starts to vaporise from the heat of the cutting disk it's as explosive as any other hydrocarbon. All aircraft jet engines use kero as fuel.
  3. Mike2007
    Mike2007
    10 Feb 2007
    1,282
    Thanks Received:
    32
    Cumbria
    Country:
    I was going to drain it dry as possible and possibly fill it with CO2 at intervals.
  4. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,030
    Thanks Received:
    450
    Country:
    CO2 is heavier than air and can sink to the floor of a cellar suffocating anyone working in there
    If using dry ice in theatre there are strict rules about orchestra pits and understage access
    Thought about a reciprocating saw ?
    • Thanks Thanks x 1
    • Like Like x 1
  5. bernardgreen
    bernardgreen
    3 Nov 2006
    22,704
    Thanks Received:
    2,137
    Bedfordshire
    Country:
    When the inner surfaces of the tank, wet with kerosene, are exposed to air there will be a large area of evaporation to produce vapour.
    Kerosene vapour mixed with air creates a high risk of explosion.
    Kerosene vapour being heavier than air can fill a basement and suffocate persons.
    Safety advice available HERE
    • Like Like x 1
  6. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    6,378
    Thanks Received:
    1,417
    Northamptonshire
    Country:
    How did the tanks get in there, and more importantly, will they come out the same way they went in?
  7. KenGMac
    KenGMac
    24 Aug 2010
    2,787
    Thanks Received:
    478
    Ayrshire
    Country:
    To be honest, this venture is not for a DIYer --- have a go?--- NO leave this to the Pros.
  8. oilboffin
    oilboffin
    26 Apr 2011
    1,665
    Thanks Received:
    247
    isle of Lewis
    Country:
    Take an electric saw after mopping out the liquid make sure plenty of ventilation and fire extinguishers.cut into small bits I've done loads.Bob
    • Like Like x 2
  9. Sponsored Links
  10. JohnD
    JohnD
    15 Nov 2005
    63,018
    Thanks Received:
    3,332
    Whale Island
    Country:
    Cook Islands
    it used to be the practice, before welding petrol tanks, to put a steam-hose down the filler pipe, and run it until the entire tank was filled with steam and it was escaping through every opening.
    Full of steam --> no air --> no explosive mixture --> no flame inside or in the escaping fumes.
    Small containers are sometimes filled with water for the same reason.
    • Like Like x 1
  11. Mike2007
    Mike2007
    10 Feb 2007
    1,282
    Thanks Received:
    32
    Cumbria
    Country:
    Access is terrible and I think things have been altered over the years.
    • Thanks Thanks x 1
  12. Mike2007
    Mike2007
    10 Feb 2007
    1,282
    Thanks Received:
    32
    Cumbria
    Country:
    I like this idea, seems to make sense.
  13. Mike2007
    Mike2007
    10 Feb 2007
    1,282
    Thanks Received:
    32
    Cumbria
    Country:
    Yes a reciprocating saw is probably better on this occasion, I'm so used of pulling out the grinder.
    Drill a decent hole the start the saw (after forcing steam into it)
  14. bernardgreen
    bernardgreen
    3 Nov 2006
    22,704
    Thanks Received:
    2,137
    Bedfordshire
    Country:
    Ventilation. Extractor fans must be intrinsically safe and be a type designed for use with explosive vapours.
    CO2 fire extinguishers can fill a basement with CO2 gas and suffocate the person(s) in the basement using the extinguisher
    • Like Like x 1
  15. Mike2007
    Mike2007
    10 Feb 2007
    1,282
    Thanks Received:
    32
    Cumbria
    Country:
    Thanks the advice I totally agree with what you are saying here.
  16. Jackrae
    Jackrae
    20 Nov 2012
    2,063
    Thanks Received:
    338
    Dumfriesshire
    Country:
    and have a cr4p before you start - saves on the washing if things go wrong :p
Loading...
Share This Page
