X
xbot
Hi all,
I went to my locla Wickes today to pick up some boards to lay in my kitchen. I am trying to match them to some existing boards so was please to find some which were 20.5cm thick Redwood PSE which is a near perfect match. Closer inspection of the boards though revealed some water damage, the manager said they had been left outside and because of the plastic packaging some mould has developed, he offered me the 4 packs of (5 x 2.4 meters) for £48 - 48 metres in total so I paid £1 per meter.
Now that I have go it home I am starting to wonder if this was a bargain, is it safe to put this down?
This is the worst of the damage:
Another but with less damage:
This is a board from the middle of the packet, top and bottom look ok but side has some damage:
This is a board which I have cut down and sanded:
I have read that you can kill the mould with bleach but most guides say that it will not penetrate porous materials. My fear is that there is mould below the surface.
So what are your thoughts, should I take it back or use it?
Thanks.
Rob.
Thanks.
Rob.
