Hi All,
Would anybody mind casting an eye over this and letting me know if im thinking along the right lines?
Ive recently moved into my first house and the screed floor in a small extension (less than a couple years old) has lifted and cracked all over.
I thought it might be damp or condensation from ontop of the slab underneath as ive found a couple signs of slight water damage on one edge of laminate flooring where the old front room meets the edge of the extension.
Had a poke around and the extension back wall has a double layer of damp course 3 bricks apart (possible because my garden in on a steep slope?).
The first layer was compleately supmerged under damp muddy pea shingle used in a 8inch gap between a patio and the wall and the bricks look wet. This looks to me like it would be just under the floor level letting moisture in, while the upper layer of damp course has protected the walls.
Im digging it all out below the membrane to see if it all drys out before getting a professional in to redo the floor.
Do i need to do anything else? And what would you recomend i do about the patio gap so this doesnt happen again?
Thanks for your time.
