Damp in corner of upvc window
28 Dec 2025
Hi, we're renovating our house at the moment and we've noticed there is a damp patch in the corner of our window after heavy rain. This is really frustrating because we've just paid to have the room skimmed.
Looking outside it looks like someone has removed a brick and just filled it in with mortar.
Any advice on how to fix this? Do we need to remove all the mortar outside to see what's going on? I'd really prefer if I don't have to damage the inside plasterwork if that's possible.
Remove mortar.
Cut a brick to fit.
You can buy ready mixed sand and cement mortar.
Fit the brick..
Point up
When dry silicone around window frame to seal.
Tips....
I'd put some masking tape on window sill so you don't scratch it up.
You can cover the new brick and surrounding bricks with duck tape so you don't make a mess of the face with cement stains.
  • Thanks
Reactions: ree
Does the window cill go all the way into the corner?
Andy
Do you mean the outside? I think it does but it's hard to tell without removing all the sealant to see whats going on. Inside the window cill does go all the way to the corner yes and then the plasterer has skimmed right down to it
May well be getting thru anywhere on the frame then running down , is that a hole below the external sill ?
Image #2- it looks like someone ran silicone under the gap between the window and sill.
My lay understanding is that the water is supposed to drain down in that cavity (which seems to have been blocked by the silicone).
Hopefully @crank39 and @Rodders53 will take the time to advise further. On is a fitter, the other makes the units (I think). Regardless, they are two of the people whom I respect when it comes down to uPVC installs (there are other people as well though).
