Hi Everyone,
I own and rent a 1920's terraced house with some damp issues and want to do more than repaint with damp seal again!
After some reading I remain a little confused. The damp is ostensibly rising from the adjoining walls with the houses at each side. I realise 'rising damp' may not be the correct diagnosis and that its a little more complex than that. Having takne some plaster off, as it was well on its way anyway I find the lowest bricks have previously been injected but could have been decades ago. Some of the revealed brickwork has the typical white fluffy salt deposits and some is blackened and slightly moist to the touch. The floor is concrete which is probably the cause of the problem as I don't think this was the original constuction. Its a middle downstrairs bedroom.
Certainly don't have the money to dig out the floor and replace with a suspended floor. For context the house is only worth 70k. I have read that tanking will work fine for a while probably several years but will force the moisture else where eventually. I have read injecting is also probably just sealing an area, again failing in the future and or spreading it else where. I also don't know how effective injecting is if its already been done in the past.
I read that the damp is probably being forced to the base of the wall by the impermiable concerete slab and no ventilation or other place for it to go, made worse by condensation. I have read that if the water/damp has a place to evaperate safely the problem can be as near as solved. I gather dry lining with a timber wall lining batoned against the wall so its not against the wet brick work and some vents installed will allow safe evaperation. This technique being the origins of the T&G wood lining to a dado rail.
Does any of this make sense or am I talking crap?
If dry lining is the best move should I replaster the now bare brick with normal plaster, remembering its a little wet, leave unplastered and just dry line from the brick work or what?
Unfortunatelky my time frame is very small as the students are returning and I only a have a couple of weeks to sort.
Thanks for the help,
