Danesmoor 20/25 lock out
13 Jan 2020
Hello,
I've done a couple of searches and found a possible answer. what is happening is (standard behaviour?)...
lower orange light is on. press the reset button, lower orange light switches off. the motor fires up, and a couple of seconds later, the whoosh
anything from a couple of minutes to 15 minutes later, the whoosh stops, I hear a relay click. the motor stays on for about 30 seconds, then the motor stops, and the lower orange light on the control panels lights up. (boiler is quiet)
some searches have said it might be the transformer? I did a search and found these two
theheatxchange.co.uk/worcester/transformer/87161566960/sku_WOR87161566960
theheatxchange.co.uk/worcester/ebi-052f0004-transformer/87161427300/sku_WOR87161
427300
does anyone know the difference between the two and which one I want? or if anyone has a different link to the item. or a different fault suggestion
I should say, the boiler (owned by parents) has been looked at by an engineer [don't know which] more than once, he couldn't find a fault.
[in advance,,thanks]
gracias. the guy came out to look at it for apparently a third time, this time the fault happened while he was watching, replaced solenoid, boiler has been behaving itself so far for 6 hours - basically a fix
3 visits to diagnose a common fault.
I hope he's not charging per visit. .!!
to be honest - the first visits, the fault didn't actually manifest itself - the boiler ran ok while he was watching it. this visit was the first time it locked out while watching
