danfloss timer upgrade
5 Feb 2014
Aberdeen
Hi
I have a danfloss set1e timer switch for Central heating.
Problem I have that it only has two programmable setting On / Off twice a day. Same times everyday.
I have seen timer that can be set at different times on different days and was wondering if its possible to change the timer switch I have for a better one with having to change to much.
thanks
Jim
Just need to find a decent electrician now.
That's like asking a question in the electrical section about lights, then saying you need to find a decent carpenter. :wink:
Better with a plumber/heating engineer.
If I knew the correct way of doing this job I wouldn't have needed to post on the forum.
Thanks again for initial help.
Just pointing out that you asked a plumbing question in the plumbing section, and a plumber gave you the answer.
So, plumber/heating engineer is best to wire in new timer on ch system.
Some sparks aren't always keen on ch.
