Can anyone out there help.
My friends central heating is up the spout.
I have traced what i believe is the problem. It is a Danfoss 5933 actuator. it is 3 way as there are 3 pipes running from it.
I took the switch off the valve body and all the plastic is broken behind.(I think she must have hit it with the hoover whe she was putting it away cos the actuator is just above floor level........ brainy positioning or what?)
So here's what I need to know.
1) Is the Danfoss 5933 a mid position actuator.
2) as the valve moves freely can I just replace the motorised switch?
3) If I can just replace the switch, is there any other make of switch that would fit on the Danfoss body or will I have to replace like for like?
4) Can you buy just the switch because I can only find them with the valve attached?
Cost is a major issue here as my friend is strapped 4 cash so the cheapest options would be appreciated but not so cheap as it breaks 6 months down the line.
