Has anybody fixed an older FP 715 controller. Fault is the 24 Volt supply powering the two relays.One relay energized drops the supply to 18 ish volts.
Both relays drop the supply to 10 Volts, thus both relays drop out and on a timed run, the relays start turning on and off. The easy answer is new one, but before I start faulting on it has anyone had the same fault and fixed it.
A couple of posts had the same fault, but just replaced the controller and all was well. Don't want to replace the controller if a 10p component will sort it.
Andy
Andy
