Dangers of whacking too early
11 Apr 2006
Berkshire
I completed my walls up to DPC level this weekend. I have a Whacker now too, and just need to rearrange my hardcore a bit before compacting. Is there any danger that I compact too close to the wall too soon, and damage the wall because the cement hasn't gone off?
I've not put a weak fill in yet, which will help matters.
Gary
Gary
I worried about this when doing my extension, so I did the weak fill in the bottom of the cavity first. I have seen the whacking done with only a thermalite inner skin up to DPC, and there were wooden props pushing the walls in - it seemed a bit silly though. I'd put in the weak fill first.
Simon.
I have two courses of 7N blocks on the inner skin at the moment, so a bit beefier than thermalites, but still!
I'll put the weak fill in this week and then leave the compacting until Saturday I think. The blocks will have had a week to go off then.
Gary
You should always fill the cavities (up to 225mm below dpc) with lean mix prior to compacting.
