    Dismiss Notice
Is this OK? Concrete floor install.
Discussion in 'Building' started by mrbiscuit, 11 Jul 2021.
  1. Notch7
    Notch7
    15 Sep 2017
    24,718
    Thanks Received:
    1,760
    S. Uplands
    Country:
    It sounds like the builder had some 120mm Celetex left from another job - I’ve cut down the odd bit in the past, but only a total muppet would try to cut boards in half for the whole floor -anyway the building inspector would never accept that. I’m not even sure 60mm would be thick enough.
    Preparing a floor for a new slab is pretty basic stuff, how could he get it so wrong.
    • Like Like x 1
  2. Sponsored Links
  3. Scarlet Pimpernel
    Scarlet Pimpernel
    9 May 2020
    7,402
    Thanks Received:
    132
    Country:
    France
    If you are DIYing it, and you want to make it really easy for yourself, assuming it'll be a pour straight in, you can order self-levelling concrete, It's a decent bit more expensive, but if there's only one of you, it's worth it.
    • Like Like x 1
  4. mrbiscuit
    mrbiscuit
    3 May 2021
    22
    Thanks Received:
    3
    Country:
    That's really good to know. Thanks.
  5. mrbiscuit
    mrbiscuit
    3 May 2021
    22
    Thanks Received:
    3
    Country:
    Hi All.
    I will be terminating my contract with the builder.
    I'm getting some independent opinion on the cost of work so far, but I would appreciate it if someone could chime in with a ball park figure for the following work, not including cost of materials, which I have receipts for:
    1. Removal of about 10 square metres of suspended wood floor (boards and joists). These were moved into my garden, not taken away.
    2. Installation of a culvert and drain. This involved one portable mixer full of concrete, approx 30 bricks and 10 metres of drain pipe, haunched in at either end. This drain was completely within the walls of the house, and involved just being laid on the ground and set with a little dry mix.
    3. Barrowing in and err, 'leveling' of 5 dumpy bags of MOT type 1 and 1 dumpy of sand.
    In total, I estimate from my records about 5 or 6 hours work.
    I understand it's very hard to gauge, but just a ball park figure would help me with my approach to things today, before I get opinion from people with 'eyes on' the situation.
    As ever, many thanks.
  6. mrbiscuit
    mrbiscuit
    3 May 2021
    22
    Thanks Received:
    3
    Country:
    @Notch7 I'm just pricing up the materials left on site. Can you tell from the pictures if it is really Celotex, and if so which of their products it is?
    From a search it looks like it's maybe TC3120, which is specified as flat roofing insulation.
    The packaged boards have no markings other than 120mm with the code 417470...
  7. mrbiscuit
    mrbiscuit
    3 May 2021
    22
    Thanks Received:
    3
    Country:
    Quick update.
    Had Building Control in today. They were very unhappy with what the builder has done, as expected.
    On the bright side though, they were also super helpful, and I got a lot of useful information from them. I'm embarking on the work myself, which will consist of removing a lot of the daft stuff that the cowboys stuck in.
    I'll make use of the hardcore and sand, level it properly and blind it with a proper layer of sand. I've agreed with building control to drain the incoming water from the wall directly through the front wall and into a land drain that will run along the front of the house. Seems to be a far more reasonable thing to do - get the water out of the house as quickly as possible.
    Anyone have any opinions on insulation types and position? I'm wondering if there are any advantages to having the insulation on top of the concrete slab and screeding over that. It seems to make much more sense to me to have the insulation above the slab - easier heating and all.
    Thanks,
    Rich.
  8. Mr Chibs
    Mr Chibs
    28 Jul 2015
    895
    Thanks Received:
    154
    Country:
    Sounds good with BCO.
    You will wonder why you bothered with the cowboys when you’ve done it yourself.
    Insulation above the slab Is meant to heat more quickly than when it’s below the slab.
    You will be needing 60mm-75mm of screed. presume you’ll be screeding conventionally as opposed to liquid pumped?
    • Like Like x 1
  9. Sponsored Links
  10. sxturbo
    sxturbo
    12 Jan 2014
    3,699
    Thanks Received:
    546
    Essex
    Country:
    Good to hear you have a way forward.
    Insulation ontop of slab,
    • Like Like x 1
  11. Scarlet Pimpernel
    Scarlet Pimpernel
    9 May 2020
    7,402
    Thanks Received:
    132
    Country:
    France
    With conventional heating, (i.e. carbon fuel boilers) insulation is more usually placed on top of slab, as others have said, it provides a shorter heating up period.
    But putting insulation below the slab, although requiring a longer heating up period (something like 4 hours as compared to something like 2 hours) it does provide a greater latent heat situation.
    With the move towards alternative heating systems, e.g. air or ground source heat pumps, the longer periods, and greater latent heat potential may provide benefits, and potential future proofing, for changes to the other heating systems.
    Here in France, there are now government grants for such changes to heat sources. But, apparently, it is of greater benefit to more modern homes, (insulation, draught free, etc).
    As others have said, insulation above the slab may require a slightly deeper screed layer.
    • Like Like x 1
  12. mrbiscuit
    mrbiscuit
    3 May 2021
    22
    Thanks Received:
    3
    Country:
    There's currently only about 140mm between the top of the sand and the bottom of the skirting boards.
    I might gain a little extra when it's compacted, but I'm guessing not much, considering I'll have to add a bit more to blind.
    Considering that some of that would be the finish flooring, I don't have much room to spare do I?
    Just taking a nominal 20mm for the final flooring, would give me 120mm for the slab, insulation, dpms and screed.
    It's not enough is it?
  13. sxturbo
    sxturbo
    12 Jan 2014
    3,699
    Thanks Received:
    546
    Essex
    Country:
  14. Mr Chibs
    Mr Chibs
    28 Jul 2015
    895
    Thanks Received:
    154
    Country:
    Think you may struggle but there will be a bright spark along, I’m sure With a solution.
    from dpm layer, I had 100mm slab, 100mm insulation, 65mm screed and 20-25mm floor covering = 300mm approx.
    I’m sure regs will insist on 100mm minimum insulation.
  15. cdbe
    cdbe
    22 Nov 2009
    1,330
    Thanks Received:
    240
    Oldham
    Country:
    Ask your bco, I believe the minimum may be 75mm, forget the screed, and 100mm slab on top. You may get away with trimming the door bottoms a bit, your limiting factor will be the bottom step of your stairs. Don't forget your perimeter insulation.
    The reality is, you'll probably have to live in the house for a hundred years to get any payback in terms of energy saving so just try and do the minimum. I understand your reason for involving building control but you'd have been better with just a dpm, slab and some self leveling on top.
Loading...
Share This Page
