Danifoss TS715 Si how to set temp for CH to come on please?
25 Jun 2012
Call me thick, call me stupid but nowhere do I see how to set the temperature for when to turn the Central Heating on? Have I been stitched up? Any help appreciated.
Cheers
Oh, I have a Glow Worm Flexicom cx boiler and Danifoss RX1 receiver.
The TS715si is just a timer; it does not have any temperature setting facilities. You need either a separate thermostat or you can change the TS715si for a programmable thermostat.
Typical! Thanks for your info and for taking the time to reply. Much appreciate it.
I have the old Worcester Digistat. Would you happen to know if this would work as is [after I remove the Danfoss TS715 Si unit?
TP5000si is the unit that talks to RX1 not TS715 :o
TP5000 allows you to set time and temperature
