DAY Visconic Powermaster 10
19 May 2020
does anyone know how to get the installer password so that I can enrol a new PRI sensor or even default on to factory settings.
Thanks Bob
well you can default it I guess, however you may find the sub engineers code still valid?
as an engineer I can't give it out, but fairly sure you cant have searched for it.
Sorry it's an ADT Visconic powermaster 10 (auto correct) . They are different and it is not out there.
Thanks Bob
Its the same process and yes its out there, however it is possible that ADT equipment is slightly different and may not learn on unless its an ADT part.
However that isn't something I can be certain of, ebay might get you an ADT part.
You should be able to check an existing part on the system for details and you can verify as an ADT part or a generic visonic part.
Okay thanks I have the part but was told that it was different so no problem I will try and install it .
Will close the thread . Thanks for your help appreciated.
Thanks Bob
