Planning a side extension and just trying to work out what would be deemed an acceptable room width in most peoples experience (especially you builders).
I have a decent amount to play with however the house is not parallel to the boundary so the available space is wider at the front than the back.
I would like a minimum 1m path down the side of the house. Does this sound enough? I based this on being able to walk down comfortably and get any large pieces of machinery down the side, e.g a mini digger is around 90cm wide.
This would enable me, at a push to get a building width (including exterior wall) of around 3.3m. So the path at its minimum would be 1m.
This would result in an internal width of around 3m.
How does that sound as the total width of a room which will be used as a bedroom/study?
As I said, this is just building a wall parallell to the house.
I guess the alternatives would be to build parallel to the boundary (not a fan of this) or having a step in about three quaters of the way back.
Any thoughs?
Thanks.
Any thoughs?
Thanks.
