An electrical supply to decking will be provided by an electrician (from a spare way on the existing shed CU with RCD protection that he connected a year ago) when he comes to do some other work in the house. I'll ask him to terminate in an external double socket attached to a post, or maybe a wiska box.
The decking isn't yet complete, and I will want to extend the electrical provision when it is (clipped to joists under the deck). This should be a simple job not worthy of his time - but what's best to use, more SWA or something like hi-tuff or rubber +/- plastic conduit? If it's SWA I will probably have to get him back later because it looks like a pain to gland off into every socket/FCU/switch/light.
I may also add some low level 12V deck lighting - these seem to plug in and have a short lead to a transformer before the 12V cable. Would I be better off cutting the plug off and attaching the cable directly to an external fused switch instead of leaving plugged in to an external socket? Do these transformers need to be situated in a waterproof box?
