Decking load
6 Jan 2016
hi....
we moved into a new house last year, the previous owners had a hot tub in some decking in the garden which they took with them. I'm looking to buy a hot tub but want to be 100% sure the decking will take the weight.... It's obviously had one on in the past but I'm not sure of the size of the last one.... The decking is in very good condition and looks and feels sound. Is there any way I can calculate the load bearing capacity just to be sure?
1000L =1 tonne
take the water in the tub then add perhaps 50-100% for the tub and people in it
Is there any way I can determine how much weight the decks by can take though?
not really as we dont know construction method
timber sizes
timber spans and spacing
support quality
ground quality
how long did the previous family have theres ??
did you ask off any problems they had with it
if you dont know or cant find out the answer them aim for something lighter or smaller than what they had
try and get several large people [not kids]on the area jumping up and down and see what happens
A picture tells a thousand words.
So some pics of the construction, showing in the hole thats left etc will enable the folks here to help you better
A 2.5m diameter tub filled to around 800mm deep will have a water load of 4 tonne, add to that the weight of the tub itself. Go buy a load of bricks of equivalent weight and lay them out evenly in the shape of the tub. If the deck sinks or collapses you've proven it won't carry the weight. It it doesn't sink or collapse then you've proven it will work. You are now in the market to sell 4 tonne of bricks and maybe some firewood. :D
Weight distribution is the important thing, although very heavy the pressure per square ft is about the same as a fully loaded fridge , so depends on the design of the hot tub as well as the decking.
