decking onto concrete roof
5 Jul 2006
Leeds
I'm not sure if what i want to do is possible or not so need a bit of advice on a couple of points:
We have a garage at the back of the house with a concrete roof that is used as a balcony/patio. The roof is leaking into the garage at one side so I need to re-seal it somehow. Afteer i've sealed it I was thinking of putting decking on top to make it look nicer. I've got a couple of doubts though and can't think of any ways around them.
Firstly, how would I secure the decking frame to the concrete roof withoug causing leaks?
Secondly, how would water be able to pass the sections of the frame to escape to the gutter?
Rob
the frame can be laid onto small slabs. The deck does not need to be secured down its own weight will hold it. try picking up the materials in one go if you dont believe me
if its on teh slabs water will pass through underneath
assuming your use is unnoficial if you are doing a more perminant job you should check with your council before decking the area as you may need planning permision for the decking as its more than 300mm above ground level!!
You could use epdm on garage roof loose laid and hold down with floating decking, running support timber in same direction as fall, to allow drainage.
