declining shower pressure
23 Jun 2006
My shower and bath both run off the same pumped supply from the HW cylinder using a 3 bar pump. When in the shower, after a while the hot water pressure drops and the flow starts to trickle out of the shower head. However, I've noticed that if I turn the shower off, then turn the hot water tap on the bath on, the water comes out of the bath tap slowly at first but after a few seconds it builds up to full pressure. If I then turn the bath tap off and the shower back on, full pressure seems to have been restored! This will be ok for a while then i'll have to do it again.
Any idea how to solve this and what causes it?
Its a hansgrohe I think.
What do you mean cold water to shower mains? The cold feed to the pump comes straight from the cold water tank/mains feed.
How does the cold behave, is it off the same pump, and is the bath hot tap alsp pumped or just on gravity?
The cold is also run off the pump and is spot on - always has decent pressure. The bath hot and cold taps are also run from this pump - there must be a tee somewhere to spilt the flow I assume.
