Decor End Panels
4 Sep 2010
Berkshire
I refitting my kitchen and have the fridge and freezer side by side at the end of a run. I need to fit the decor end panel but don't have a cabinet to attach it to. What's the best solution - Do I need to create a frame or can I fix it directly to the wall and the work surface (once installed)?
i use a few brackets upto the worktop and a few into the floor on the inside so they will be covered by the appliances.
you will need a 2x1 batton across the wall behind the appliances for the worktop to sit on if you havent already with a few brackets to hold the w/top down
If you have room a small infill panel at 90 degree to end panel [about 50mm wide]looks better and allows easier access to appliance and adds strength to corner.
