Decorating living room, dealing with cracks next to wooden beams
6 Oct 2015
Hey,
looking for some advice on what filler I should use here. I'm about to start redecorating my living room. The house has wooden beams and next to some of the vertical beams there is cracking in the plaster (either about 1 cm from the beam, or between the plaster and the beam).
Generally most of them is probably no more than 2-3mm wide. I'm guessing this will be a constant problem, with beam shrinkage and expansion in different temperatures, but it would be nice to put something in there that is a bit more flexible & deals with the expansion + contraction a bit better before I stick Farrow & Ball on it :). Any tips?
Let me know if pictures are required!
Cheers
19 Jan 2007
London
Decent flexible caulk, or even a frame sealant. Both will likely leave a ridge even after painting.
A lime based filler might work, is the fabric standard plaster or something with age?
6 Oct 2015
I believe standard plaster. It's a barn conversion (building is est ~1820) - conversion happened about 11 years ago.
