Apologies for being a typical newbie and steaming in with an awkward and lengthy question.
We have a 1907 mid-terraced house where the downstairs ceilings appear to be textured-finish plasterboard between beams. We initially thought the beams were load-bearing joists but it's been pointed out to us that there's filler between some beams and the plasterboard, which indicates not. The beams run in the same direction as the upstairs floorboards.
Recently I've noticed - and I'm not sure if it's because they're new, or because I've become paranoid - cracks in the paintwork around the point where the beams meet the party wall. Some of the cracks continue into the ceiling itself. The photo is of the worst one - for scale there is about 75mm of beam below the ceiling, so the crack is about a fingernails' width. Because of the thick paper/paint it's not possible to ascertain whether the crack goes into the beam itself.
We had a survey done 2 years ago on purchase which did not indicate any movement but the house is on clay soil. The one older exterior door has always stuck, more so in the winter, and is due to be replaced - it requires a sufficiently hefty slam that the vibration is felt upstairs. The cracks are worse nearest to where an internal load-bearing wall has been removed and replaced with a structural beam, we think in the 1970s.
Do I need an opinion from a structural engineer or should I watch and wait? When it comes to redecorating, can this be taped/caulked?
Should a surveyor be able to determine whether the beams are decorative or structural? If the former, I'm tempted to take them out and redo the whole ceiling with some kind of coving.[/img]
