Please help, have I got a case...
My scenario is I am having a 20m2 extension built and I used dense blocks rather than lightweight. It was a selection made following a conversation with the supplier that the existing house is dense block and is to be open plan through to the extension - therefore using lightweight blocks in the extension would not be worth the additional money they would cost as heat saving would be negligible, which seemed logical so I went ahead and got on with the order and work.
I didn't give this another thought untill the Building Inspector pulled me up on this point and said I'd have to install insulated plasterboard min 25mm insulation (so 37mm boards), I didn't think much of this until, to my horror, I inquired about the price of these boards!!
The wall construction is brick, 100mm cavity filled with 100mm drytherm, 100mm dense block.
My query is does anyone know how far off regs I am with this construction and do Building Control ever show any common sense in this scenario seeing as the house extension to the remainder of the house is open (to be open plan) and therefore will be seeing no benefit from my investment on the costly insulated plasterboard. Basically is there anything I can do????
Cheers for any advice.
[/b]
[/b]
