I've been hunting for the answer all over but can't seem to find it.
Starting from scratch - redoing floor, room is 3m x 5m currently there's a hole in the ground. Its going to be a livingroom.
So in order from top to bottom:
Floor covering
Screed with UFH pipework (65mm)
Insulation (100mm)
Reinforced Concrete slab (???mm)
Blinding sand
Hardcore/rubble infill
What thickness of concrete slab should I be aiming for to have a hard level surface to lay the insulation ontop of.
100mm seems overkill, even 75mm to me seems like overkill since there will be 100mm of insulation (Very rigid stuff!) with 65mm of screed over the top of it.
Does anyone know how to calculate it? As I can only seem to find calculations for concrete that is hanging in mid air rather than completely supported by the ground below it.
All drawings I can find on internet state exact depths for insulation and the screed, but never the concrete slab its all resting on.
What thickness should help to support the whole floor and keep it all together whilst it slowly settles down, without cracking.
Floor covering
Insulation (100mm)
Blinding sand
