- Joined
- 10 May 2016
- Messages
- 575
- Reaction score
- 82
- Country
It seems that you are unhappy about your misinterpretation of the HETAS requirements, we can discuss this in another thread if you give us the details of the installation.HETAS advice was "no bird stopper to be fitted in the chimney pot"
Insurance company underwriters "a bird stopper is recommended"
The HETAS cert was issued as "no bird stopper fitted" and then the stopper was fitted. The insurance company approve this.
Reason is that without a bird stopper birds will attempt to build a nest and enough nest material can fall down into the flue and when a fire is lit create a fire in the lining. If that fire occurs close to the top of the liner then embers could fall onto the thatch and ignite it. Enough nest material to be a serious hazard can get into the flue in a few hours when the birds are determined to get a nest built. Hence the without a bird stopper the flue would have to be swept or inspected each time the fire was to be lit.
In the meantime, you were going to tell us about horizontal runs, bends and the like... You could also throw in details of how the fire would be extinguished in the event of a fan failure in your "Up and Under" flue... Should I also ask about provisions for sweeping, condensate removal, joint inspection, flue ventilation etc etc..
