DETA carbon moxide 1121 replacement
1 Apr 2020
Hello,
We have a DETA carbon monoxide alarm Model 1121 which is now giving an end of life beep after 5.5 years so we would like to replace. Can anyone recommend a replacement that will fit the wall fitting so its easy for us to replace and also would prefer one with a battery backup.
I think the 1121 model may be discontinued, I am seeing BRK models that look very similar.
Regards
Only normally same manufacturers will fit existing back plates, and even then they don’t if they change the range. Personally I’d recommend an aico alarm.
hi there
came across this post on google
my block of flats was built 5 years ago. they also hardwired the carbon monoxide alarm
I also have the DETA 1121
It was discontinued as mentioned on here. So tried the suggestion on here for the BRK® CO850MBXi Carbon Monoxide Alar
But that is also discontinued.
Anyone have any other suggestions that will fit the ceiling plate
It's annoying as the ceiling plate feels pointless if you can't switch it out with something else.
If I get another hardwired one, is this something I need an electrician to install or does removing the DETA 1121 backplate, give me an easy connection option.
Must be loads of others in this position.
