I have a Vaillant Turbomax 837e Boiler. It has been cycling fairly strongly on the Hot Water side.
I've recently replaced the DHW Heat Exchanger which appeared at first to have fixed it, but actually it hasn't. It has improved a lot, but it's still happening. Previously it would go from maximum hot to completely stone cold, but now it luckily doesn't go so cold so a shower is possible! The Heat Exchanger clearly needed doing as I've had to turn the DHW dial down massively since (previously it was on about 80% of maximum setting, now it's on about 20-30% and is delivering hotter water overall).
It's also losing a bit of pressure on the heating side, could the 2 things be related?
