That will make it 59900 which I would say it is."If the pointer is exactly on a number, write it down and underline it.
If any of the underlined numbers you have written down are followed by a 9, you will need to take one away from the number you’ve underlined"
Well, if that's what they say.This was one of the numbers I came up with but following the guidance:
When we remember that these things are mechanical, analogue and continuous in their movement, I don't think it really matters in terms of the answer (as opposed to the 'instructions'!) - given that it's apparent that the first four dials are extremely close to being 'exactly on a digit'.Which pointers do we think are exactly on a digit?
That obviously depends a lot on which is meant to be the hour hand and which the minutes handWhat time is it?
OK, I'm happy with that.it's apparent that the first four dials are extremely close to being 'exactly on a digit'.
Indeed we do. I think what those instructions have forgotten to add is that if, using their rules, "taking one away from the number you've underlined" results in turning a 0 into a 9, then one has to 'carry' that subtraction to the left - so that the answer would become 59,900 and not the 69,990 one would get (per your illustration) if one only followed the bit of their instructions which they have actually chosen to tell people about!OK, I'm happy with that. ... Which means we underline the first 4 digits. ... Then, when we follow the rule "If any of the underlined numbers you have written down are followed by a 9, you will need to take one away from the number you’ve underlined", do we not end up with this:it's apparent that the first four dials are extremely close to being 'exactly on a digit'.
